Pharie82 opened this issue on May 08, 2002 ยท 5 posts
Pharie82 posted Wed, 08 May 2002 at 9:44 AM
I'm having a problem with my Victoria model... Whenever I select the head, a small box pops up that reads: "Exception caught... blah blah blah... Error Code 50" Can anyone tell me what this means? Can I fix it? How? Please Help! -Charli
Dagon posted Wed, 08 May 2002 at 9:52 AM
are you using Poser 3 or Poser 4 ?
webvogel posted Wed, 08 May 2002 at 10:06 AM
..sometimes it helps to delete the .rsr file and try again I know this problem from Poser 3 if you use P4 Objekts
Pharie82 posted Wed, 08 May 2002 at 10:22 PM
I'm using poser 4.
hauksdottir posted Thu, 09 May 2002 at 12:13 AM
Which model of Victoria are you using? If you have Vicky 1, there are updates to fix a couple of problems in the mesh. Vicky 2 shouldn't have problems. Also, do you have the latest version of Poser 4 from Curious Labs? I think it is 4.03, and you can get the update from their website. Having this version should solve some of the problems. The third thing I'd mention checking is RAM. A lot of the Poser error messages are because the system doesn't have enough memory to handle the higher polycount meshes. If you are on a Mac, allocate at least 200 MB to Poser, more if you have it. Carolly
