Subject: Another Stupid Question from the Peanut Gallery...what is "MOR"
starmkr opened this issue on May 10, 2002 ยท 18 posts
starmkr posted Fri, 10 May 2002 at 9:08 AM
In a lot of th new packages that I have bought here they have a "MOR" pose. What is it and what do I do with it. I checked the Poser Pro PDF and not in there. I just tried to do a search here and the page freezes... I hate having misunderstood words. Thank steve
Kiera posted Fri, 10 May 2002 at 9:15 AM
A "MOR" pose applies dial settings to a figure. After you apply it, the figure should change. In my store items, I use the term MOR to differentiate between MAT, which applies material settings.
starmkr posted Fri, 10 May 2002 at 9:25 AM
So it present Morph Dials?
Kiera posted Fri, 10 May 2002 at 9:35 AM
yes, it applies Morph dial settings.
eirian posted Fri, 10 May 2002 at 9:43 AM
It's poser shorthand :-) In theory: A "Pose" moves the body parts of the figure. (Poses can be saved with or without morph channels, but can't be saved with material settings: you have to create material poses manually.) Partial poses affect only specified body parts. A MAT (material) Pose changes the material settings without affecting the pose or morph channels. Sub-dividing MAT poses change the material settings only on specified body parts (eg to put stockings on a character without changing the main body or face texture). A MOR (morph) pose changes the morph channels without (if it's created correctly) affecting the pose. ...and all of the above should come as .pz2 files and "live" in the Poses library.
Marque posted Fri, 10 May 2002 at 10:07 AM
Is there any place that explains how to put something on a particular part of the body, say stockings or gloves without changing the rest of the map? Thanks, Marque
JOE LE GECKO posted Fri, 10 May 2002 at 10:50 AM
Change the "customMaterial 0" string. Just replace the 0 by 1 ( or 2 ... ). This way, you'll be able to change the hands-fingers texture without modifying the other body parts. The problem is that you can use MAT files after that, since they'll modify "channel" 0 but some parts will have a different one ( the one you used ). You need to make a MAT pose to bring back those parts to their initial state. Usually, make a MAT with "customMaterial 0" and NO_MAP everywhere, and you'll get back the body texture... joelegecko
Marque posted Fri, 10 May 2002 at 10:54 AM
Thanks! Off to try it. Marque
JOE LE GECKO posted Fri, 10 May 2002 at 11:07 AM
so boring we can't edit posts :( I've just read my post, and I mean you can't use MAT files after applying such a MAT pose, since the customMaterial is no longer 0 but 1 or 2... You'll have to look at the .cr2 file to find the "customMaterial" string, you may not find it in some MAT poses. joelegecko :)
starmkr posted Fri, 10 May 2002 at 11:45 AM
Thanks...I hate M.U.'s
Chailynne posted Fri, 10 May 2002 at 4:04 PM
Does this mean if we figure out how to make MOR files that some of our purchased characters could be changed into MOR files to save space on our drives instead of using them as character files? (not ones with custom morphs as I understand but dialed ones) So changing an older character to a MAT and MOR file would save space? I'm already planning on going through and making a bunch of MAT's for things I have textures for just to make them easier to use.
KattMan posted Fri, 10 May 2002 at 4:36 PM
Chailynne, that is exactly what it means. Mor files are also much smaller then CR2 files. ANd if you want a cheap tool to create these for you look in the sotre for my Poser Wizard!
eirian posted Fri, 10 May 2002 at 4:37 PM
Making a MOR pose is easy, as long as you don't use the full body morphs. Save the pose (any pose!) with morph channels included. Then open up the .pz2 in a text editor (notepad or whatever) and delete the rotate and translate values for each axis (x y z) from each body part. What's left is a bunch of settings for each body part that look like: targetGeom whatever { keys { k 0 0 } } Those are the morph channels. If all the xyz information is stripped out, what's left is a MOR pose. If you use the full body morphs, it's a little more complicated, as you have to add those to the .pz2 Poser won't save them automatically. Take a look at my Mike2 character pack (in freestuff): those are all MOR poses made on that principle. ...and, yes, if you can save a character that way you could remove the CR2 and still regain the character. Any character based on Victoria or Michael 2 should be in MOR format anyway: that's the only legal way to distribute those characters. Victoria or Michael 1 characters will mostly be in CR2 format with custom morphs: it's harder to make a MOR pose for them.
Chailynne posted Fri, 10 May 2002 at 5:26 PM
Thanks Kattman and Eirian. I'm going to have to take the easy way out and probably get Kattman's program when I get the chance. Looks like a good investment. :o)
bikermouse posted Sun, 12 May 2002 at 7:17 AM
not a stupid question. I was wondering about MOR files too. While we're near the subject all the MAT tutorials I read all seem to forget to tell you to include two closing brackets at the end of the file. } } Aren't these brackets necessary to tell Poser that the figure and the file are ending ? Message671410.jpg
starmkr posted Mon, 13 May 2002 at 9:47 AM
thanks guys for the help
atom123 posted Wed, 15 May 2002 at 12:10 AM
my god this is informative.... thanks
gstorme posted Wed, 15 May 2002 at 2:41 PM
KMI
