atom123 opened this issue on May 10, 2002 ยท 10 posts
atom123 posted Fri, 10 May 2002 at 12:53 PM
how does 1 go about making poseable/bendable rope and stuff??? say you have a flamethrower.... the "pipe" that connects from the "backpack" to the "gun".... how?!? any suggestions, or ideas??? using rhino and propack....
Cybermonk posted Fri, 10 May 2002 at 1:24 PM
Well either slice it up and make a figure out of it or use morphs to get the same effect. Morphs will probly be easier to do but will make for a larger file size.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
Cybermonk posted Fri, 10 May 2002 at 1:31 PM
Attached Link: http://www.sams3d.com/
I believe Sam's3d has a good tutorial on making figures. And there was one here in the tutorial section too(by ScottA I think).____________________________________________________
Albert Einstein
nfredman posted Fri, 10 May 2002 at 1:45 PM
Attached Link: http://www.runtimedna.com
Don't forget Ajax's Easypose tutorial on RuntimeDNA!Kelderek posted Fri, 10 May 2002 at 2:06 PM
I think Ajax has a free posable figure in Freestuff that uses his Easypose method. You can use that and apply a suitable texture to make it into a rope, hose or whatever.
Ajax posted Fri, 10 May 2002 at 4:47 PM
For what you're doing, the method I would suggest is to make a posable tube (like mine but without the EasyPose), set it up with IK and then parent one end to the backpack and one end to the flamethrower. I haven't tried it yet but that's my idea for how to approach this type of problem.
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
bloodsong posted Fri, 10 May 2002 at 6:37 PM
heyas; check the freestuff, because anthony appleyard has a backpack flamethrower kinda thing around here somewhere. or at least he was working on one from time to time. check out his scuba stuff too, the rebreathers have stuff like that.
atom123 posted Fri, 10 May 2002 at 7:19 PM
well thanks guys! im w/ ajax on this.... imma set up a tube/cylinder w/ many bones........ i can then save that as a prop, and then edit it as need be. i can stick a "dummy" on both ends, so that its stable on the ends (so it shouldnt float around, only the cable inbetween). i came up w/ this myself, i just hope it werks..........
cooler posted Fri, 10 May 2002 at 8:09 PM
Attached Link: http://www.3Dcommune.com
atom123 posted Mon, 13 May 2002 at 3:23 PM
whoa! who cares about rope now, lets pack that bad boy! tobacco products only of course, lol.
