Subject: How to add a background image?
Laverboy opened this issue on May 13, 2002 ยท 10 posts
Laverboy posted Mon, 13 May 2002 at 1:20 PM
Ive searched through the forum and pdf but cant find out how to add a background picture. how do u do this? thanks.
Kelderek posted Mon, 13 May 2002 at 1:24 PM
An easy way is to load a square prop, place it in the background and apply the background picture as a texture.
Laverboy posted Mon, 13 May 2002 at 1:25 PM
Will shadows and stuff still work?
Laverboy posted Mon, 13 May 2002 at 1:28 PM
Oh thanks btw ^.^
Kendra posted Mon, 13 May 2002 at 1:30 PM
There's also a command to "add background image" up in file I think. It's up there somewhere and it puts your image in the background without having to use a prop.
...... Kendra
Kendra posted Mon, 13 May 2002 at 1:40 PM
Also if you want shadows, download Runtime DNA's Infinity Cove. (www.runtimedna.com) Just fit your background to the texture map and you'll have shadows cast onto the background.
...... Kendra
purdon posted Mon, 13 May 2002 at 2:33 PM
In poser 4 I do "Import" and then select "Background Image".
Laverboy posted Mon, 13 May 2002 at 2:36 PM
Thanks for your help guys =p
queri posted Mon, 13 May 2002 at 7:08 PM
The only problem, for me, with using "Import Background Image" is that then the render has to be in that ratio. All my Bckgrnd Images are landscape rectangles and I usually do Square pictures. I've found no way around this. If I resize the window back to my size the background, instead of flooding the intire background, floats up in the air. ery annoying. Emily
doozy posted Wed, 15 May 2002 at 5:02 AM
Try this and see what happens: Import the background image to a scene with the same ratio as that background. THEN change the dimensions of the scene.
