JHoagland opened this issue on May 13, 2002 ยท 1 posts
JHoagland posted Mon, 13 May 2002 at 1:49 PM
Attached Link: http://www.renderosity.com/freestuff.ez?Form.Contrib=JHoagland&Topsectionid=0
Now available in the Free Stuff Section: the MAT Pose Applier Import/ Export Tool!"What is this program and what can it do?"
The MAT Pose Applier Import/ Export Tool is a small program that allows users to import and export "material definition" files for use in the Mat Pose Applier.
The major benefit of this tool is the fact that users can now exchange "material definitions" with each other, without having to replace the entire database file!
"How does this program work?"
The tool's interface is very similar to the MAT Pose Applier- you select a category and a figure (from each of the pull-down boxes). From there, you can Import a figure (from a file) or Export the selected figure (to a file).
Additionally, you can use all the same maintenance features that are found in the MAT Pose Applier- adding, renaming, and deleting categories and renaming, deleting, and moving figures.
As a word of precaution, though- any changes you make with this tool WILL be reflected in the MAT Pose Applier (since they share the same database file).
Additional Notes/ Known Issues:
If you have installed the MAT Pose Applier, you chould have no problem running this tool (since it uses the same "supporting" files that are already installed with the MPA).
Note: This tool REQUIRES the previous purchase and installation of the MAT Pose Applier in order to work (click link to go to the Marketplace, to purchase).
--John
