Marty188 opened this issue on May 13, 2002 ยท 3 posts
Marty188 posted Mon, 13 May 2002 at 3:11 PM
Is there a way that I can make the picture smaller (besides uploading a smaller picture) so that my text can be seen better?
Wadus posted Mon, 13 May 2002 at 3:51 PM
if you can edit the html you can change the code to set the size. example {IMG src="name.gif" width="100" height="100"} just replace { & } with < & >
Blackhearted posted Tue, 14 May 2002 at 9:51 AM
the best solution is just to upload a smaller image - when you resize images with HTML commands the quality degrades significantly, and if you enter an incorrect ratio you get distortion. cheers, -gabriel
