Subject: Poser Problem
petunia4life opened this issue on May 14, 2002 ยท 9 posts
petunia4life posted Tue, 14 May 2002 at 4:09 AM
I added tattoos to a texture in Photoshop 6.0 then saved it as a JPG. I loaded it onto a Michael 2.0 figure in poser and it GREYED OUT right away.. which meant that I couldn't use it. I couldnt bring it up for any other body parts cuz it was greyed out. I tried saving the same texture as a TIFF.. but it still didnt work. Anybody know what is going on here?
SAMS3D posted Tue, 14 May 2002 at 4:15 AM
Are you sure you first had Michael selected? Then you are applying it as a texture correct? In the materials editor right?
petunia4life posted Tue, 14 May 2002 at 4:24 AM
correct, i had skinhead selected then I loaded the texture.. then it greyed out right away. I cant click on it to use it.. its like poser cant or wont read it...
SAMS3D posted Tue, 14 May 2002 at 4:28 AM
hmmmm, check to make sure that it is indeed a .jpg, just to make sure, and maybe it could be the title of the .jpg, it might be to long....Sharen
petunia4life posted Tue, 14 May 2002 at 4:30 AM
I saved it in Photoshop as a JPG, I'll shorten the name and see if that works. It still shouldnt be greyed out though as if its not there... thats kinda weird
SAMS3D posted Tue, 14 May 2002 at 4:33 AM
yes it is weird, but it could be the name is to long...Poser has a thing with names. Sharen
OJM posted Tue, 14 May 2002 at 6:31 AM
Check that you don't use 'progressive compression' when saving your Jpg file ... Poser don't like it ... PhEn.
Bobasaur posted Tue, 14 May 2002 at 12:33 PM
You might also doublecheck and make sure you're saving it as an RGB file instead of CMYK.
SAMS3D posted Tue, 14 May 2002 at 12:45 PM
good point Bobasaur.....Sharen
