Tempest opened this issue on Feb 06, 2000 ยท 12 posts
Tempest posted Sun, 06 February 2000 at 11:54 AM
Well I have seen this question asked a zillion and half times but I can't seem to find one such post so ill ask the quesion. How do you import a poser character into bryce so as that you don't loose any sharpness/textures/whatever. Thanks for the help Tempest
adam posted Sun, 06 February 2000 at 12:24 PM
Hey Tempest. We meet again. Export the Poser model in wavefront obj format. This will give the character it's texture. Then just import it into Bryce and enjoy. -Adam
picnic posted Sun, 06 February 2000 at 12:56 PM
There are a number of tutorials about this. See Spike's for one in the tutorial section. You must save your Poser figure as a wavefront .obj as Adam says. Then in Bryce you do 'import object', it will start the import process and then prompt you to 'find' the texture maps--so you browse your Poser/Runtime/Texture folder for those textures. Eventually, after this is done, the figure will appear. The sky, lights, etc.--will all affect how the figure looks. THEN--you can further 'tweak' all the textures by selecting them individually (you place your mouse over the area of the part you want to select, hold down 'ctrl' and click your left mouse button. You will see a list of those 'areas' under your mouse. Select one--or, for instance, if you want to select all the 'skin' areas--hold down shift also. Then you can play with diffusion, ambiance, etc.--for just those areas. Give those selections a 'name'--like skin and you can easily 'select them again from the list of meshes. Here's the message for the little tute I did for anyone interested in using transmaps and multiple textures--its the same principle http://www.renderosity.com/messages.ez?ForumID=107&Form.ShowMessage=67896 Diane B
picnic posted Sun, 06 February 2000 at 1:00 PM
Oh, and here's the other that might be of more help. In the pic library you will see all the texture maps my figure used (and I was prompted to find when I imported her into Bryce) so you know what I'm talking about--and you will see what I mean by selecting just one area. http://www.renderosity.com/messages.ez?ForumID=107&Form.ShowMessage=68021 Hope this helps. Diane B
TyggerBob posted Sun, 06 February 2000 at 2:32 PM
Is it just me or did the OBJ export get a zillion times better in Patch 116? I remember Having to group things, and set the textures and everything after exporting from P4 to Bryce, but now, it's a breeze.. Maybe I was doing something wrong before, I'm not sure Anyway.. I'm sure happy with the results, now :) TyggerBob
adam posted Sun, 06 February 2000 at 2:54 PM
Patch 116? Where did you get it?
TyggerBob posted Sun, 06 February 2000 at 3:01 PM
That's a Poser patch, not a Bryce patch it's at: http://host-1.ghosteffects.com/poser/patch/patch.html Kinda gross because you have to re-install Poser to use it though. TB
Ghostofmacbeth posted Sun, 06 February 2000 at 3:17 PM
I have still been waiting till they get the patch figured out .. also don't realy hae the hard drive space right now so I have to wait until I get my new drive installed but it sounds cool
picnic posted Sun, 06 February 2000 at 3:46 PM
Hmm, don't know. I don't have any of the patches--I'm like Ghost--waiting for the 'early adapters' to get through all the hitches of the beta versions. I haven't had to group to texture. Normally the textures DO come in with the figure. I think only once did I really have problems. HOWEVER, all that having been said--I STILL twiddle with the textures--but primarily just to 'tweak' them into looking even better--or to use more than one texture kind of 'after the fact'--like I did using Tim's Asian texture but using Diane TG's Nikko eyebrows, etc. I sometimes do the same for clothing--I often make several textures for things or import others and so can change those too. That, however, is just how I do it--not a necessity. P4/B4 has worked quite well for me. Diane B
adam posted Sun, 06 February 2000 at 5:04 PM
Thanks for the URL, Tiggerbob. I am going to download it if you can aply the textures easier in Bryce. Thanx -Adam
adam posted Sun, 06 February 2000 at 5:06 PM
Jim Burton posted Sun, 06 February 2000 at 8:37 PM
Tempest- As they said, use .OBJ, and get the patch for Poser, even the first (now gone) patch greatly improved exporting. I've also found that Bryce will still choke on the more complicated figures, when mine keeps accessing the disk for more than a few seconds after I tell it where the textures are I know it isn't going to make it- I then bring the figure in without textures and apply them all, which isn't all that hard once you know how to do it, I mean I might spend an hours getting the lighting right so 5 minutes to load 10 texture maps is no big deal. The unpatched Poser would hardly ever load a figure with a conforming item on it. and it would also combine figures, making it imposable to manually map them unless you text edited the .obj file.
