Subject: Can I save a face?
Rynn opened this issue on May 16, 2002 ยท 11 posts
Rynn posted Thu, 16 May 2002 at 6:45 AM
I got Poser 4 a few days ago, and ofcourse I already have a question. :) Today I used the parameter dials to make some changes to Victoria's face. I would like to save this face. So I tried to find the answer in the manual, but I always end up saving the entire figure. Does anyone know if and how I can do this? Rynn.
Kelderek posted Thu, 16 May 2002 at 7:03 AM
There are several ways of doing this, one is to make a morph target of the face. Select "Export" from the file menu and chose "Wavefront OBJ". The hierarchy editor will appear, make sure that the head is the only body part selected. (It's only settings for the head that you want to export in the morph) Then you assign a file name and a location for the file you are about to create. In the last dialog box, check only the box "Export as morph target". When you want to use the face later, just double click on the head of the character you want to apply the face to. Click "Add morph target" and locate the file you created before. After that, the morph will appear as a dial for the head. Adjust the dial to 1, and you have your face on the figure! You can of course change any other dials after that to make further changes on the new figure. You can also use MOR files, they are explained in numerous threads and tutorials here, do a search on the site. They are easier to apply when you have made them, but it requires a little more understanding of the Poser file types to get them to work properly. Wwelcome to the Poser world and happy rendering :-)
Rynn posted Thu, 16 May 2002 at 7:39 AM
Thank you, this helps a lot. :) Rynn.
LeeEvans posted Thu, 16 May 2002 at 7:44 AM
I've always just fixed the face I wanted, then opened the "Face" library, and added the file to a personal foler... i.e. "Lee's Faces" ... Seems to work for me that way... -Lee
Kelderek posted Thu, 16 May 2002 at 8:06 AM
Yep, that is even easier! :-) Both methods has it's merits. With the morph target, you can easily apply the morph gradually by adjusting the dial. You can also build a face from several different morph targets since they work independently from each other. The Face file is easier to make and apply, but might get "overrided" by other face or pose files if they contain settings for the same morph channels.
Alleycat169 posted Thu, 16 May 2002 at 9:04 AM
You don't need to export the head mesh to create a Morph Target. Just select the Head mesh by clicking on it and pull down from the Menu/Object/Spawn Morph Target. Give the Morph Target the name of your character. A new dial will appear at the top of the dial menu with the name of your character. You only need to export the Morph Target if you are going to distribute it, otherwise it is an extra step you don't need to take.
SAMS3D posted Thu, 16 May 2002 at 3:01 PM
Just wanted to pop in and say welcome.....Sharen
Rynn posted Thu, 16 May 2002 at 3:20 PM
Thanks for the help and for the welcome. :)
smerc posted Thu, 16 May 2002 at 6:20 PM
Welcome to the forum Rynn. There is a banner near the top of the forum (Poser Forum Resources) that links to Poser FAQS, Tips and Tricks, challenges, etc. Plus the folks here are really friendly. smerc
Rynn posted Fri, 17 May 2002 at 2:11 AM
Thanks smerc, I already found all those links. There is a lot of interesting information there, which will help me a lot. :) Rynn
ronknights posted Fri, 17 May 2002 at 8:12 AM
I'm not sure why people mess with morph targets. Just add the face to your Face Library. You can even share those faces with others.. You don't need to worry about copyright problems. Here's an example of my latest Work In Progress. I always have a problem coping with morph targets. I wonder why we need to do it the hard way, anyway?! Ron ![Message671422.jpg](http://www.renderosity.com/photos/Message671422.jpg)
