hogwarden opened this issue on May 17, 2002 ยท 6 posts
hogwarden posted Fri, 17 May 2002 at 10:43 AM
Just doing a tiny bit of research... Are there many users out there who have the French release of Poser or Propack? I'm making PB compatible! Howard:)
akin_ posted Fri, 17 May 2002 at 1:36 PM
Attached Link: http://akin.free.fr/poser.htm
Any problem Pal ? The main thing you should know is Poser uses different names for the internal folder, it's cool, but quite a nasty thing for programmers of helper application ! =)hogwarden posted Fri, 17 May 2002 at 4:32 PM
Erdehel posted Sat, 18 May 2002 at 5:13 PM
Howard, That's exactly the way the runtime folder looks like in the french version of Poser. Robin
akin_ posted Mon, 20 May 2002 at 1:55 PM
Yes Indeed ! It's a major problem ! Dan from CR2Edit has managed to overcome it... Good luck ! If you need any more help, my mail is akin@free.fr Cheers, A'kin
hogwarden posted Mon, 20 May 2002 at 3:23 PM
Yep... It's all sorted. PBooost is now at 1.2... (although it's not up at Rosity yet.) and works for the French releases. The Compatibility tester is updated and in Freestuff. IM me if you wish to know where the actual PBooost is available!! H:)
