MeInOhio opened this issue on May 18, 2002 ยท 4 posts
MeInOhio posted Sat, 18 May 2002 at 6:06 AM
I think I understand the process alright. The only thing I haven't figured out is this: I transfered the morphs other to the shirt (as one morph). Saved it out with a new name. Went back to Poser. Loaded Michael. Set muscular1 to 1. Loaded the shirt. Set all the shirt parts to 1. Created a full body morph. Set all the individual parts back to zero. Set the fbm to one and resaved it to my library. But when I load the "muscleshirt", I still have to set the fbm to one. Is there a way to make the one setting the default on load? Thanks. Kevin
Styxx posted Sat, 18 May 2002 at 6:30 AM
there are two ways.. After you set the fbm to 1, click edit>memorise>figure then save it to the library.. doesn't work all the time, but usually(for me anyway) The other way is to set the initial value of the fbm to 1 right in the cr2. Just open it in word pad and do a search for the name of your morph. Where you see, initValue 0 change that to 1 Then save the cr2. That should fix ya up :) Cheers, Noel.
ronknights posted Sat, 18 May 2002 at 6:56 AM
MeInOhio posted Sat, 18 May 2002 at 7:00 AM
Thanks for the help, Noel. And I haven't looked at your tutorial yet, Ron, but I will. Thanks, again. Kevin
