Subject: If you use the Poser Pro Max Plugin with Shag Hair/Fur- I need your help!!
object22 opened this issue on May 21, 2002 ยท 1 posts
object22 posted Tue, 21 May 2002 at 8:36 AM
(i also posted this in the max forum) How do you get your shag vectors to align and rotate properly throughout the Poser animation? I have tried so many different tricks and nothing works correctly. I am using vectors for the arms. hands, legs, feet, and body- and I need the vectors to bend and rotate correctly with the Poser mesh. If you use these plugins together how do you get them to work? Thank you so much in advance for any help!!
