Forum: Poser Technical
Subject: FBM's exporting as morph targets...
dke opened this issue on May 22, 2002 ยท 3 posts
dke posted Wed, 22 May 2002 at 10:21 AM
I seem to be having a problem exporting morphs that are part of FBM's. I export using the "...as morph target..." checkbox but it doesn't come out right for the dial settings that are part of an FBM - like the SuperHero settings. So I'm thinking it must be one of two things 1) My cr2 is messed up 2) It's a Poser/FBM thing If it's (2) then I suppose I could go in and convert the FBM's back to stand alone settings, but I think it's the scaling info that is causing the problem and so would need to change that to ...??? Anyone privy to this situation? Thanks Bruce
Ericroy posted Wed, 22 May 2002 at 11:15 AM
Bruce, You're going to love this..... When saving the morph, set the FBM to 0. Set the morph dial on the body part to the desired setting. Then (are you ready?) export the body part WITH THE SAVE AS MORPH TARGET BOX UNCHECKED!!!!! Isn't that a hoot? I don't know why, but that is what works for me. I hope this helps, Ericroy
bloodsong posted Wed, 22 May 2002 at 4:35 PM
heyas; if you're checking 'as morph target' AND 'weld body part seams' that happens to equal 'zero all morph settings.' try setting the fbm, then export 'as morph target,' but turn off the seam welding. i'm not 100% sure that works, so check. if it doesn't work, then you need to set the individual body part morph dials, but you can still use 'as morph target' as long as you don't also use 'weld body part seams.'
