I've modeled a Poser jacket in Carrara and ran it through UVMapper Pro. So far it conforms reasonably well. Now I want the add a couple of morphs to close and open the jacket. I pick the chest area and export it from Poser as a morph target (no world trans formation). I then open the object file in Carrara, make the changes and re-save it. When I attach it as a morph target in Poser and twist the dial the jacket's chest area splinters. I've attached a picture showing the Carrara settings I used and the results in Poser. I am looking for any advice you can give! Thanks! mike
cutcopypaste, I left a reply yesterday (or so I thought!) but since it didn't stick I just wanted to say thank you. Your reply and your tutorial worked perfectly, so I can now create morphs as well as base meshes in Carrara! Thanks again! mike
