Subject: My camera poses don't save.
Mitch1 opened this issue on May 25, 2002 ยท 4 posts
Mitch1 posted Sat, 25 May 2002 at 9:54 AM
I go select camera after i have a view I like, then when I open the other Poser file where I want the camera view to be applied nothing happens. What am I doing wrong?
jelisa posted Sat, 25 May 2002 at 2:27 PM
Are you saving the camera settings to the camera library before opening the new file? When you open the new file, it's saved camera setting will become the default. Try saving the camera setting to the camera library, open the new file and apply the camera setting from the library.
Roy G posted Sat, 25 May 2002 at 2:52 PM
You could try using the Camera Dot's. These are kind of handy sometimes.
Just click an empty camera dot to set it.
Alt click a Dot to clear it.
It even selects the correct camera for you. Something camera Poses don't do for some reason.
Mitch1 posted Sat, 25 May 2002 at 3:06 PM
For some reason I haven't noticed the Camera folder. I was saving the camera in Poses DUH! Once I saved in its folder it worked. Thank you, guys.
