Subject: Spandex Vicki and Mike
Grey_cat opened this issue on May 26, 2002 ยท 15 posts
Grey_cat posted Sun, 26 May 2002 at 8:22 PM
I used the grouping tool to assign a new material called "Uniform" to the areas covered by the spandex morph. I feel this works better than the Catsuit, because it's part of the figure rather than a separate figure, and all the morphs work. They use a new object file, and a new cr2 file. If there is enough interest, I will try to make them available for free.
Grey_cat posted Sun, 26 May 2002 at 8:24 PM
Voluptuous Vicki using the "UniformF" object file.
Grey_cat posted Sun, 26 May 2002 at 8:25 PM
One of my characters using the "UniformM" object file.
queri posted Sun, 26 May 2002 at 8:35 PM
If you have Stephanie, could you do one for her too???? Emily
movida posted Sun, 26 May 2002 at 9:43 PM
really clever, I'd like it also if you can, and thank you
PabloS posted Sun, 26 May 2002 at 9:47 PM
I'm interested! However since it sounds "derivitive" you might run it by Daz first.
Grey_cat posted Sun, 26 May 2002 at 11:09 PM
Stephanie won't work, there's only a partial spandex morph (chest and hips), I need the neck and wrists to tell where to end the material change. The object files will be pcf encoded, but I'll still need DAZ's OK.
Dave posted Mon, 27 May 2002 at 1:33 AM
Mike morphs can transfer to Stephanie so you might be able to move what spandex morphs you need to her. I would also be interested in this Uniform characters.
FishNose posted Mon, 27 May 2002 at 2:17 AM
Oh yeah, definitely interesting! :] FishNose
bantha posted Mon, 27 May 2002 at 7:22 AM
I'm intrested to!
A ship in port is safe; but that is not what ships are built for.
-"Amazing Grace" Hopper
Avatar image of me done by Chidori
Grey_cat posted Mon, 27 May 2002 at 10:05 AM
OK then, Spandex Stephi
Dave posted Mon, 27 May 2002 at 11:03 PM
Ok. Now when might this possibly be available? Definitely interested in Steph and Mike2
Larry F posted Tue, 28 May 2002 at 12:53 AM
That's beautiful. I'm definitely interested in that for Mike, Mike2, Steph, whosomever! Great stuff! Will that be in freestuff?
TigerD posted Tue, 28 May 2002 at 5:14 PM
Or, more importantly< when...?
spratman posted Wed, 29 May 2002 at 11:36 AM
Yeppers, I'm definitey interested. Not to be greedy a tutorial would be great too, doesn't sound all that hard. Since I've been using the Lores Vicky2 alot and I'm assuming the regular Vicky version wouldn't work I'd like to be able to take advantage of this for that model. thanx!
