Prop Viewer Version 2.0 (preview) VERSION 1.0 You can see Poser prop files *.pp2 without the need of Poser. It don't works with props that don't have internal geometry (they call some *.obj file located somewhere) WHAT'S NEW (Version 2.0) - added 3ds files viewing. - added dxf files viewing (only with 3dsface entity). - added obj files viewing. - You can load a *.jpg texture for all the object. You cannot use several textures at the same time. Jpeg progressive not supported. - You can associate PropViewer with *.pp2, *.3ds, *.dxf and *.obj files, so clicking with explorer this files you can see them. If you associate *.zip files with Winrar you can see props inside zip files (This is great). I think that Winzip will also works, but Winrar is very much better than Winzip. - Some improvements in speed. - You can believe this, but the version 2 is better, has more functions and is much smaller than version 1 (~350k vs 1100k). This breaks the rule that newer versions have allways bigger size than the older ones. Comming soon Wait..........
Stupidity also evolves!
