Subject: modify a texture
Jessy_Dee opened this issue on May 28, 2002 ยท 7 posts
Jessy_Dee posted Tue, 28 May 2002 at 2:31 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=190404&Start=1&Artist=Jessy%5FDee&ByArtist=Ye
hi! i wish modify the vvbottom and top adding logos or a picture, can somebody help me with a tutorial or something? thanks, by the way im newbie
smerc posted Tue, 28 May 2002 at 5:09 PM
What do you have for a paint program? And how good are you at using it? smerc
smerc posted Tue, 28 May 2002 at 5:10 PM
The image looks good by the way. Nice pose and expression
Jessy_Dee posted Tue, 28 May 2002 at 5:19 PM
well, i have paintshoppro 6, and know a little how to use it
smerc posted Tue, 28 May 2002 at 5:48 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12365
I do not have paintshop pro :( Assuming you can create layers though I am willing to give it a try. -Find the texture you want to modify. -Open it in PSP -Create a new layer -Paint your logo on that new layer (maybe just some simple text) -Save file as testfile.jpg -Open Poser and load your character. -Click RENDER-MATERIALS and select the correct object(object drop down menu) (the top or bottom, whichever texture you modified) -Then choose the material (material drop down menu) -THen uncheck "texture changes apply to entire figure" -In the texture map area click on load and select testfile.jpg -Click OK Now when you render your image the material you specified should have the logo you created. If you need more help with a specific area just ask. IF you need more PSP help then I suggest the Paint Shop Pro forum for more help (follow the link) smerc
Kelderek posted Wed, 29 May 2002 at 3:20 AM
I have PaintShop Pro and it does use layers, smercs approach will work nicely. Just remember that the .jpg file you create will lose all the layer information (the .jpg format does not support layers). Therefore, you should save the texture as a .psp file as well, just in case. You might want to do some additional work on the texture after you have tested it in Poser, and it will be nice to have a .psp file to work on that still has your additions on a separate layer.
Jessy_Dee posted Wed, 29 May 2002 at 11:59 AM
thank you very much!!!!! :x
