Kolschey opened this issue on May 29, 2002 ยท 4 posts
Kolschey posted Wed, 29 May 2002 at 11:21 AM
Hey all, I am building a new custom character. The original geometry was built in RHINO 2 and exported as .obj geometry. I am able to import this file into Carrara/Raydream or Poser 4.03 (with Pro Pack). Now when I export the figure from Poser as an .obj file, and then try to bring it into Bryce 5, I get the message: "Bryce 5 A file error has occurred (i/o, bad media)." Has anyone else experienced this? Is there a workaround? Many thanks!
Rochr posted Wed, 29 May 2002 at 3:03 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=690018
Try this one and see if it helps!Rudolf Herczog
Digital Artist
www.rochr.com
Kolschey posted Thu, 30 May 2002 at 8:26 AM
Yes! Thanks to the #IND replacement function, the object imported properly with nary a complaint! Considering that this is not a rocket science issue, though, I reckon that Curious Labs might want to consider patching this wee bit of code in the next service release for their Pro Pack.
jelisa posted Thu, 30 May 2002 at 7:36 PM
Glad the #IND fix worked! -darlisa
