photographex opened this issue on May 29, 2002 ยท 5 posts
photographex posted Wed, 29 May 2002 at 11:42 PM
I have installed photoshop 7 in windows xp, but when i get ready to open it I get an error saying ....parameter is incorrect....can anyone give advice? oh yeah i did try the compatibilty thingy with no luck .someone ...please help.
dreamer101 posted Thu, 30 May 2002 at 12:02 AM
I am running winxp pro corporate edition and have installed photoshop 7 without a problem. Do you have the home edition or professional edition?
retrocity posted Thu, 30 May 2002 at 12:53 AM
There are a couple of things you can try...
(this one goes without saying: make sure your system meets the minimum requirements to run PS)
1.Install the latest "service packs"
try running PS alone
Recreate the "pref" file in PS (search for Prefs.psp and rename, then launch PS)
Verify your device drivers are compatable with XP (sometimes a scanner/TWAIN driver can crap out on you and kill the launch)
Check and change (if needed) the virtual memory paging file.
Check your fonts (because PS loads a font list at launch it can crap out there to).
try to watch the splash screen as PS launches and see where it dies on you, than post back here.
good luck,
RetroCity
MephistoLV posted Thu, 30 May 2002 at 9:12 AM
Try putting your Photoshop 7 cd in your cd tray and then launching it. I had the same problem. I don't know what caused it, but this is what fixed it for me. I only had to do this once. It now works fine. Hope this works for you.
Usurer posted Sun, 02 June 2002 at 1:58 PM
I had a helluva time getting mine to work. I just got busy doing
other stuff and came back to it about a month later and then..
doing the same things i did before when it wasn't installing, it
installed! >_
