etep opened this issue on May 31, 2002 ยท 6 posts
etep posted Fri, 31 May 2002 at 4:42 AM
hi, i am hoping some of the experts here can tell me how i can keep an object ( the main subject ) in my render sharp and in focus if i use depth of field as in a photo,
i have tried selecting the object (ie it is the only object with red wire frame), :>) help please!!
vasquez posted Fri, 31 May 2002 at 5:32 AM
Sorry but I can't clearly understand your problem. Did you used the DOF in the render options? And if so did you check the option to "current selection"?
vasquez posted Fri, 31 May 2002 at 5:34 AM
P.S. "to current selection" is the grey button under the values of the camera settings of the DOF
Erlik posted Fri, 31 May 2002 at 6:37 AM
And rendering has to be set to Premium.
-- erlik
Stephen Ray posted Fri, 31 May 2002 at 1:07 PM
Even when using the options for DOF to set the focal point, the object used, will still be slightly blurred ( even more so if it's a group ) I do a DOF render, then a regular render, than an object mask render. And use Photoshop to combined the two renders using the mask.
dan whiteside posted Fri, 31 May 2002 at 7:27 PM
Attached Link: http://www.bryceworks.com/tutorial/doftest.html
Size matters.Make all your objects rather large and do the "to current selection" and start with a lens radius of .01 and go up from there. The above URL shows some simple examples. HTH-Dan
