administrator3d opened this issue on Jun 03, 2002 ยท 8 posts
administrator3d posted Mon, 03 June 2002 at 1:11 PM
Chi mi sa dire perchVue 4 va sempre in crash con nt e bisogna sempre resettare il PC????????????? C'forse qualche trucchetto che io non so ?? grazie
gebe posted Mon, 03 June 2002 at 1:40 PM
Attached Link: http://www.e-onsoftware.com
OK, I understand what you are asking for, but my italian is too bad to answer you in this language. Do you have Vue 4.06-02? If not, please update at e-onsoftware. Guittagebe posted Mon, 03 June 2002 at 1:42 PM
If you encounter problems after updating, please write again.
audity posted Mon, 03 June 2002 at 1:56 PM
--- message translation : "could you tell me why VUE 4 always crash with NT and I always need to reset the PC ? Is there a trick that I don't know ? thanks " ---- there could be many reasons why VUE 4 crashes : 1. You are running an older version of VUE 4. Get VUE 4.06 at www.e-onsoftware.com. 2. the driver of your Open GL graphic card is not compatible with VUE 4 (It happens frequently !). Disable Open GL in VUE option's or get an industry standard driver. 3. Your version of VUE is not correctly installed : - uninstal VUE and clean all the VUE entries in the registery. - restart your PC and make a clean installation of VUE 4 and directly after the VUE 4.06 FullUpdate patch. 4. Your NT system is unstable, re-instal Windows NT ! If you don't understand english, we will ask to "guigui" to make a translation. :) Eric
gebe posted Mon, 03 June 2002 at 2:05 PM
Traduzione dalla risposta del Eric Ci potrebbero essere molte ragioni per le quali VUE 4 si arresta. 1.) State facendo funzionare una pivecchia versione di VUE 4. Ottenga VUE 4,06 a www.e-onsoftware.com 2. Il driver della vostra scheda grafica aperta di GL non compatibile con VUE 4 (accade frequentemente!). Inabiliti GL aperto nell'opzione di VUE o ottenga un driver di campione di industria. 3.) La vostra versione di VUE non installata correttamente: - Uninstal Vue e puliscono tutte le entrate di VUE nel registery. - Ricominci il vostro PC e faccia un'installazione pulita di VUE 4 e direttamente dopo la zona di VUE 4,06 FullUpdate. 4.) Il vostro sistema del NT instabile, re-installa Windows NT
audity posted Mon, 03 June 2002 at 2:10 PM
cool ! instant translation ! Guitta you are amazing...
Bop posted Wed, 05 June 2002 at 5:12 PM
Another skill that we can credit to gebe ??? Is there something you can't do ?... :-)
gebe posted Thu, 06 June 2002 at 3:37 AM
LOL, Bop
