Subject: How do I Reduce 'shinyness' on skin?
arcady opened this issue on Feb 14, 2000 ยท 11 posts
arcady posted Mon, 14 February 2000 at 4:54 PM
Attached Link: http://www.geocities.com/arcady0/Robin/
How do I cut down the 'shinyness' on the skin of my figures. I like the outfit being shiny in this case, but not the skin. Notice her right shin in particular. There's a few 'sample' renders at the URL there, but it's the same problem all around.
Truth has no value without backing by unfounded belief.
Renderosity Gallery
JeffH posted Mon, 14 February 2000 at 5:00 PM
Set the highlight color to "black" at 100%.
Nance posted Mon, 14 February 2000 at 11:08 PM
Or, try using a bump map created from random noise. Breaks up the highlights and can give the skin a more realistic irregular surface texture.
arcady posted Tue, 15 February 2000 at 1:41 AM
Well, getting home from the day's events I look at the file and it did have a black highlight on the skin at 71%. Setting it to 100% didn't give me a noticable effect on this figure. I'll see what the bump map idea will do. Once I figure out how to make one of random noise... :)
Renderosity Gallery
arcady posted Tue, 15 February 2000 at 2:10 AM
Well. I just did two test renders with noised bump maps. One using a 300300 noise bump map that gave no 'for sure' effect. The other at 20002000 pixels made her look like a surviver of an extreme case of chicken pox. With skin resembling the surface of a crator pocked moon... So, any recomendations as to what sort of setting I should go for?
Renderosity Gallery
Nance posted Tue, 15 February 2000 at 10:00 AM
Sounds like you just have the bump map level set too high. Try single-pixel sized noise on a map 2000x2000 and set the bumpmap level to around 10-20% in the surface materials box. The effect also depends on how close your figure is to the camera. Should get something like this. p4_0002a03e_temp.jpg This image is from a new skin texture WIP. This one had the level set at 20% on the skin (perhaps a little too high still) and 100% on the nipples. Skin highlight value was 44 and nipple highlight was 244.
Nance posted Tue, 15 February 2000 at 10:13 AM
And, by "100% black" I believe Jeff meant to set the highlight luminance value to zero.
JeffH posted Tue, 15 February 2000 at 10:42 AM
I got the skin settings from Steve Cooper. Highlight Black set to 100%. He said something about it spreading the highlight more evenly over the figure...
arcady posted Tue, 15 February 2000 at 10:52 AM
Ah. I set highlight to 100% on the dial. Btw, how did you mange to get a picture posted in a message reply? I don't see anything for including a picture in here. Does it accept html in the body of these things? I wanted to post what I was getting last night but couldn't figure out how to without starting a whole new thread (which seemed like a waste).
Renderosity Gallery
JeffH posted Tue, 15 February 2000 at 10:54 AM
Yep, HTML image tags work...
Nance posted Tue, 15 February 2000 at 12:45 PM
Whoops! Sorry about the confusion. I was refering to the settings for Highlight "Color" and Jeff is refering to the slider for Highlight "Size". HTML tag to include an image in a post: (img src="the/URL/for/your/image.jpg") replacing the parentheses with greater-than and less-than signs.
