Subject: P3 problem
Techie opened this issue on Jun 04, 2002 ยท 5 posts
Techie posted Tue, 04 June 2002 at 9:41 AM
hi, i'm a newbie of sorts (to poser anyway), and i'm trying to find poser3 models and textures (prefably free, due to me being skint), and haven't had much luck. Any help would be appricated .Techie.
SAMS3D posted Tue, 04 June 2002 at 10:13 AM
Attached Link: http://www.sams3d.com/Freebies1.htm
I don't know right now but I will keep a look out for you, we have some free models you can take that will work with Poser 3, go grab some if you need them. We have lots, most you can pose....Sharen
AlShoshana posted Tue, 04 June 2002 at 4:15 PM
Hi Techie, I have a similar problem! I'm trying to figure out how to make my own stuff, because poser 3 stuff seems thin on the ground. If you go to Phil C's website, he has some characters and stuff for poser 3, a lot of them are in the freestuff section here. If you look through these posts, you will find one from bloodsong called something like "the BBN is here" ...it's a norn and it works perfectly in poser 3 for me (thanks bloodsong :) best thing I've got!) If you are looking for tutorials, or general how to information, check out tutorials here, then go to curious labs website and at the bottom of their download page is an advanced techniques manual for poser 3, which has tutorials on making morph targets, creating new figures etc... and from their links page you can find some good tutorials, some of which are for poser 3 as well as 4. Happy hunting, if I find any good stuff I'll let you know, Al.
bloodsong posted Tue, 04 June 2002 at 6:03 PM
heyas; you can always try p4 figures in p3. depending on what the p4 figure has in it, it may or may not work fine in p3. some things that don't work in p3 are -- more than 99 morphs on one part transparency and/or reflection maps (but the model should still work okay) figures that use multiple maps on different materials (although i'm not sure about this one). i know over on poserforum.net that english bob actually got victoria to work in p3, but you might want to check out the details of things like that before you plunk down any money on stuff advertised as p4 only. :) oh, also before you go poking around with 'this file has a higher version number than expected,' you should backup the main files in your poser base directory. especially that poser.rsr. you can write-protect that one, as well. it gets clobbered a lot.
peejay posted Tue, 04 June 2002 at 6:27 PM
Attached Link: http://www.3dcommune.com
Also don't forget our good friends over at 3dCommune, tons of free stuff over there that works fine in Poser3
