Forum: Bryce
Subject: Glowing Lines
psychomoose opened this issue on Feb 15, 2000 ยท 3 posts
psychomoose posted Tue, 15 February 2000 at 2:11 PM
Hi everyone does anyone out there know of a good material setting for a thin line (specifically a torus) which will give a nice soft edge and reflect into a metalic texture, but not fade in visibility as the angle of view changes? I have to create a series of magnetic rings around an object for an illustration, which is ok, but as they are viewed face on rather than for an angle- 30 degrees inward- they become totally translucent, which is no use as they have to reflect into the metalic surface of the object which they are surrounding!!! I would be happy for any suggestions! Psychomoose psychomoose@yahoo.com
Spike posted Wed, 16 February 2000 at 10:53 AM
Uh.... What? I don't understand. could you give a sample? Spike
You can't call it work if you love it... Zen Tambour
KenS posted Wed, 16 February 2000 at 4:05 PM
did you try adjusting the transperancy of the material and the reflection?
