Forum: Carrara
Subject: OK... maybe I'm missing something???
Nate opened this issue on Jun 07, 2002 ยท 3 posts
Nate posted Fri, 07 June 2002 at 5:54 PM
I do mostly print media work.
A large amount of is is medium resolution at 200 DPI (dots per inch,not Pixels).
RDS offered the option to choose your dimension units as inches. I haven't found that in C2. I suppose there is a formula for instance if you needed to render an image that was going to print at 200 DPI and you wanted the image to be 8 inches by 10 inches.
That would be easy to set up in RDS, but seems a bit of a mystery to me in C2. The on-line (Acrobat manual) says you can go the size panel and enter your dimensions AND CHOICE OF UNITS (ie: inches, etc.) I'm not finding that.... I found the size panel, but nothing that lets you change units.
thanks for any tips on this one!!
On-line portfolio / Making figurines in China / Gallery  / Video Demos
