arcady opened this issue on Feb 16, 2000 ยท 2 posts
arcady posted Wed, 16 February 2000 at 11:07 AM
Hello; On the Carrara CD there are several models that are figures of people or animals. How would I go about giving these figures all the info they need to be posable figures in Poser? Is there a cr2 file or something on the Poser CD I can use to build the info for them? Or is there a more automated proccess one can use? What sorts of things do I have to check for in the figure's files to make sure they will be capable of this process?
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
ClintH posted Wed, 16 February 2000 at 12:39 PM
arcady - Its a long process...Here is the short version. 1) Break up the mesh and name the body parts. Break the mesh where ever there is a joint. Export from RDS or Carrara as OBJ. 2) Use UV Mapper to get a Texture Template for your OBJ file. 3) Use PHI Builder to build the figures heirarchy. 4) Convert the PHI file in poser using File-> Convert Heir. 5) Set the Joint Parameters (JP's) inside Poser for all moving parts. 6) Save the character to a library in Poser. This will create the .CR2 file. Thats the short and nasty of it. Once I have a mesh to start choping up it usually takes me about 24-48 hours of work to get things done. If you have a some specific questions let me know. I will be glad to help. Clint
Clint Hawkins
All my life I've been over the top ... I don't know what I'm doing
... All I know is I don't wana stop!
(Zakk Wylde (2007))
