Patricia opened this issue on Jun 09, 2002 ยท 10 posts
Patricia posted Sun, 09 June 2002 at 9:23 PM
Downloaded it 3 times over trying to get a "cybersuit--bump.jepg" file that Poser would convert to a bump map, but no luck . Tried it with a prop before installing, and with the figure itself after, but Poser doesn't even ask if I want it changed and the field comes up "No Bump". And then it refuses to render because of "missing textures/bumps." Very strange.... Never had the problem before, so I'm hoping someone else has, and will share the answer--I want to use it in the Avatar Challenge and time is running out
lalverson posted Sun, 09 June 2002 at 9:56 PM
can't say I had any problems works ok for me. I just gotta actually use it in a posting render.
Patricia posted Sun, 09 June 2002 at 10:13 PM
Thanks for responding, lalverson. I wish I could figure out what was wrong.....
pendarian posted Sun, 09 June 2002 at 11:19 PM
you might try resaving the file as .jpg instead of jepg....just a wild guess :) And then having poser convert it. Pendy
tiamatdx posted Sun, 09 June 2002 at 11:20 PM
works fine for me also
Patricia posted Sun, 09 June 2002 at 11:30 PM
Damn. Wonder what I'm doing wrong? Thank you for responding. If your resaving with a different extension doesn't work, Pendy, I guess it's back to the search for a replacement.....I'm not finding anything similar, tho....and I'm running out of places to look.....just not my day, I guess!
n3k0 posted Sun, 09 June 2002 at 11:42 PM
Works fine for me also. I've downloaded mine on June 1. The text file shows the files as having .jpeg extensions while the actual files in the ZIP have .jpg extensions. I remember in the free section someone creating MAT poses for the suit?
jarm posted Mon, 10 June 2002 at 1:39 AM
Ditto, not a problem for me either. Perhaps the merchant could send you the bump map zipped up or resend you the jpg, you might try unpacking again, maybet he file was damaged during unzipping? best wishes Jody
Patricia posted Mon, 10 June 2002 at 10:43 AM
It was likely just the file--I didn't know about the MAT pose version, and the download from the store did unzip oddly, I remember. The rest of the contents of the file unzipped as usual, but the textures were still in Zip format when I opened the folder to check. They then seemed to unzip when I put'em through seperately, but I think the file I downloaded was corrupted. The creator has been in touch, and very helpful, so I'm hoping the store will straighten it out. Thank you for your responses---I was feeling very discouraged yesterday!
JeffH posted Mon, 10 June 2002 at 1:19 PM
An updated version is in, redownload your purchase to get it.
