Moebius87 opened this issue on Jun 11, 2002 ยท 4 posts
Moebius87 posted Tue, 11 June 2002 at 3:58 AM
If I modeled a briefcase full of money as a Poser prop... what do I need to do so that I don't get into trouble with the US Treasury Department? Or is this a bad idea?
Mind Over Matter
"If you don't mind, then it don't matter."
Jcleaver posted Tue, 11 June 2002 at 8:26 AM
I don't think you would have a problem, but just in case I would probably use similar markings but not the actual markings of the bill in question (ie use a pic of Albert Einstein instead of George Washington). I do know that if one were to use a dollar bill in advertising, the size would have to be either half sized, or twice the size if the bill pictured is very similar.
Cinema1954 posted Wed, 12 June 2002 at 9:52 AM
Attached Link: http://www.secretservice.gov/money_illustrations.shtml
See this website.Annie
Moebius87 posted Wed, 12 June 2002 at 10:25 AM
Thanks, Cinema1954, I guess I'm okay then... It will not be printable... and the texture map of the currency will have the center portion deleted (because there is a strip of paper to hold the stack of bills together anyway). I will be creating a single sided texture (no reverse textures), and will be changing the overall color of the image. Whew!
Mind Over Matter
