Blacksteel opened this issue on Feb 17, 2000 ยท 3 posts
Blacksteel posted Thu, 17 February 2000 at 2:25 PM
PhilC posted Thu, 17 February 2000 at 4:21 PM
Hi Blacksteel, The "magic hair" prop was intended to be used on its own not in conjunction with the other hair pieces. If its not required simply delete it from the scene. I have included above the transparency/colour settings if required. If you require additional help, I am very happy to answer emails at pcooke@mis.net Regards PhilC
Paul Hafeli posted Thu, 17 February 2000 at 4:45 PM
BlackSteel: The problem you are having is usually cause by the Transparancy Falloff having a value other then 0. When you want to make something fully transparant the falloff must be set to 0 ( Zero ) Paul Hafeli
