Forum: Bryce
Subject: Attn: Diane-Distance Rendered
dhanco opened this issue on Feb 18, 2000 ยท 3 posts
dhanco posted Fri, 18 February 2000 at 4:48 PM
This is the image after the mask was applied. I don't know if you can attach more than one image here, so here is the 'after' .. Deanna
Spike posted Fri, 18 February 2000 at 5:14 PM
Looks like you got it! Now all you need to do is invert the selection then apply filter. Keep in mind that you can use this on any type of filter. Spike
You can't call it work if you love it... Zen Tambour
dhanco posted Fri, 18 February 2000 at 5:32 PM
Thank you for the help. I thought I did invert it, but I should test using a different image. The trees don't really show the difference that much. Thanks again .. Deanna
