seadog opened this issue on Jun 18, 2002 ยท 15 posts
seadog posted Tue, 18 June 2002 at 4:05 PM
Here's a noob question for ya'll that's been buggin' me. Why is some hair that I download or buy show up in the figures library rather then the hair library? And how can I get it to properly stay in the hair library, or should I keep it in the figures library if that's where it installs too?
JimX posted Tue, 18 June 2002 at 4:25 PM
Most hair is like a special prop. It should go into the Hair library, and Poser will handle it just like it is supposed to. Sometimes an artist will create hair that is a conforming figure. It works more like clothes. So you can add it to your scene, and conform it to your person. This kind of hair needs to be in the Figure library. So the answer to your question is that you should probably leave the Hair objects where they are installed. Now all you have to do is remember where they are. Personally, I moved all of the figure-type hair objects into one folder in the Fiogures library, so I could find them. - JimX
seadog posted Tue, 18 June 2002 at 4:31 PM
Thanks mate, I appreciate the advice. Arrrrrrrr, ------seadog
Allen9 posted Tue, 18 June 2002 at 4:40 PM
Yeppers, I've got a "Posable Hair" folder under Characters. I've also discovered that renaming prop, character, etc folders in the library with names all starting with 2 digits (i.e., 01Clothing, 02Jewelry, 03Misc etc.) I can re-order all my library subfolders in any sequence I like - helps since I now have some 50 folders under props alone, and like the ones I use most to be at the top of the list. This way I've even got all the weapons separated in different folders: 10archery, 11knives, 12swords, 13axes, etc. - anything to make life a little easier when I'm snarled in the throes of creation.
FyreSpiryt posted Tue, 18 June 2002 at 5:44 PM
I go the opposite way, rename hair figures to "hr2" files instead of "cr2" files, and move them into a hair directory for the character they're intended for. They work the exact same way (i.e. they'll still load as figures, just like they would in the figures library), and I know right where to go to get what I want instead of trying to remember if DesiredHair1 is a figure or a hair prop.
hogwarden posted Tue, 18 June 2002 at 6:13 PM
You sure, fyrespirit? Haven't got tome to try it out, but I trust you! Damn useful! I'll add "moving hair character files to Hair folder" to the PBooost "to do" list! Howard:) Oh, and shiver me timbers.
Moonbow posted Tue, 18 June 2002 at 9:22 PM
Could someone remind me where pz2 files go please? I downloaded the candles files for the Wander's Tavern and they are pz2 files instead of prop files like all the rest of the Tavern files. Now I'm kinda lost... Thanks:)
Netherworks posted Tue, 18 June 2002 at 9:40 PM
scifiguy posted Wed, 19 June 2002 at 12:50 AM
Moonbow, pz2 files are poses so they go in your poses directory.
FyreSpiryt posted Wed, 19 June 2002 at 7:21 AM
Abso-fraggin'-lutely positive, Hogwarden. ^_~ All of the poser files are essentially the same, the only difference is what sections are included when saved and the extension. Because of this, if say your pose section gets full, you can move things over to lights and camera. You can rename clothes figure to props, and then they won't try to replace your base figure when you load them. And you can move hair figures to live with hair props. We're all just one big happy family of Poser files. : )
Jim Burton posted Wed, 19 June 2002 at 2:01 PM
Hey, FyreSpiryt, it works! I never even thought of trying that (putting renamed hair figures in a hair folder). I'm going to have a conforming version of the Hollywood hair available shortly, now I can keep it in the same folder with the hair props, thanks for the tip! You learn something new about Poser every day!
FishNose posted Wed, 19 June 2002 at 6:34 PM
Fyre, that's amazing! Thanks! But if I save a new version of the hair figure, say with new morphs, can I save it straight into hr2 or must I go via cr2 first? Jim - a hair question for you too - your Hollywood hair - I was just using it. It struck me, that there are no MATs to go with it. Have you done any for the update? :] FishNose
FyreSpiryt posted Wed, 19 June 2002 at 7:22 PM
Fishnose, I'm pretty sure you'll have to go through CR2 first. because of the way Poser saves things. No way to know for sure except to try it, though.
SergeantJack posted Thu, 20 June 2002 at 1:48 AM
Excellent tip, FyreSpiryt (and great name, too, although a little hard to type!). I appreciate it.
Jim Burton posted Thu, 20 June 2002 at 8:51 AM
Oh yeah, it (the Hollywood hair) predadted MATs, but there will be MATs when it is updated, probably some new colors and even a couple new morphs, too! I still use the shorter version of this hair all the time, myself.
