diomede opened this issue on Jun 18, 2002 ยท 2 posts
diomede posted Tue, 18 June 2002 at 9:51 PM
My transparency files work fine for most clothing. For some reason, the female biker shorts seem to leave a residual filmy reflection in areas that should be transparent. I've tried setting the reflection setting to different colors and different numbers. I even tried using the group tool to eliminate sections of the thigh. Nothing seems to be working. Is there a simple solution I'm missing?
Little_Dragon posted Tue, 18 June 2002 at 10:27 PM
You know those areas of the transparency map you painted black to make transparent? Paint the texture map pure black (RGB 0,0,0) in those areas, also. What you're seeing are probably highlights, not reflections. Highlights don't show up against pure black.
