Subject: The free stuff area has been changed
smerc opened this issue on Jun 20, 2002 ยท 24 posts
smerc posted Thu, 20 June 2002 at 5:00 PM
1.) You can now define whether or not an item is acceptable for Commercial Use. 2.) You can now define whether or not an item is a Stand Alone item or an Add-on item. Also, the Free Stuff Search has been modified to accommodate these changes and to include these criteria in the search. So if you wish to have your items take advantage of the new parameters you need to update your items accordingly. That is if you are concerned about how your items are used and whether or not they are stand alone or add-ons. Also, all items are defaulted to Non-Commercial Use and as Stand Alone Items. You will have to change them as needed. ' ' ' We should have an open discussion on subject two so we are all on the same page. I would take this to mean the following: "Things that only require the standard Poser 4 would be a stand alone (morphs for the Dork, textures for the strapless dress, a prop). If you have to download or purchase something other then the standard Poser 4 to use your free stuff item, then it is an add-on (morphs for vicky, textures for smerc's wonderful peacock chair ;)" What do you guys think? smerc
