Wed, Feb 26, 10:17 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 11:54 pm)
Subject: Rendering with Sketch Render
TalmidBen ( ) posted Fri, 21 June 2002 at 12:32 AM ยท edited Fri, 13 December 2024 at 1:29 AM
Hey friends, I just found out how to render a picture larger than the window in Poser 4, by going into render options. However, is it possible to render a sketch style render, larger than your image window, or is it possible to do a sketch render through render options? If so, how? Ben
Netherworks ( ) posted Fri, 21 June 2002 at 12:51 AM
Yes it is. Set up the sketch you want to use in the sketch designer. Then, go to Animation Settings and set the frame for the size you want to render, and set Frame Rate & Frame Count both to 1. Then, click on Make Movie. Set Sequence Type to Image Files, Resolution to Full, and Quality to Current Sketch Settings. Then click ok and it will output to the format of your choice. :)
Don ( ) posted Fri, 21 June 2002 at 12:54 AM
Attached Link: http://Cyber-Fyber.bbay.com/images/CF-DLfiles/SketchDesignTutorial.pdf.zip
DL my Sketch Design Tutorial. It has info on that feature as well as rendering larger size and resolution images.
