thomasrjm opened this issue on Jun 21, 2002 ยท 6 posts
thomasrjm posted Fri, 21 June 2002 at 2:50 AM
Having trouble with rendering both Mike and Vicky, the textures aren't loading? Have done big searches in the tex folder but nowhere to be found. Has anyone else experienced this, I think I've scratched a hole in my scalp, in a word I need some ..... hellllllllppppp.
Thanks, Tom.
hogwarden posted Fri, 21 June 2002 at 3:10 AM
Sounds like you've accedentally deleted or moved the textures... try doing a full search of your HD for the textures. If they're gone-for-good, you'll have to re-install Mike and Vicky. H:(
thomasrjm posted Fri, 21 June 2002 at 3:17 AM
Thanks hogwarden, I have reinstalled both without any luck. Did have this problem once before and they turned up in a strange folder but cant remember where, obviously too many hours at work today has clouded my memory.
Tom.
hogwarden posted Fri, 21 June 2002 at 4:26 AM
Wierd... Hopefully, if you're on a PC, the textures fill turn up if you do a full "Find files or folders"!! H:)
darkphoenix posted Fri, 21 June 2002 at 4:34 AM
runtimetexturesDazcharacters or runtimetexturesZygotecharcters try those directorys, its the default install for the high res textures.
thomasrjm posted Fri, 21 June 2002 at 5:33 AM
How embarrassment!,thanks guys it seems the textures are a seperate install which I think I forgot to load on my last reformat. I checked for the Daz and Zygote tex folders with no luck, now reviewing all my CD's #%^x!*#!
Tom.
