Subject: Think I have a problem with my new friend?
TheWanderer opened this issue on Jun 22, 2002 ยท 4 posts
TheWanderer posted Sat, 22 June 2002 at 4:07 PM
Hi Been playing around with the Gorilla, as has everyone else it seems. but well I noticed this dark shadeing on his arm,shoulder and back, has anyone else had this problem I can't see ant prob with the texture files but then again I am using the All map P4 mat file, it only shows on rendering, light set up default. otherwise I love the model well worth the money first one i've ever bourght. thanks Dave
sirkrite posted Sat, 22 June 2002 at 5:05 PM
I just got it this morning. I'm not having that problem. Default lighting and All map P4.
RHaseltine posted Sun, 23 June 2002 at 9:16 AM
You are using P4, not ProPack are you - this sounds like what you get if you use a PP MAT file in P4 and the jpeg bump maps confuse it, though I would expect PP to handle P4 bump maps correctly (or not at all).
TheWanderer posted Sun, 23 June 2002 at 4:29 PM
Hi yes thanks I went through and reinstaled it again no diff but what I did do was to recreate the bum maps from the jpgs again and applied then seperatly, this time it seems to work I'll applie the mat files and save the character so I don't have this problem again. Thanks Dave
