Forum: Bryce
Subject: plopp render question
thgeisel opened this issue on Jun 23, 2002 ยท 3 posts
thgeisel posted Sun, 23 June 2002 at 9:24 AM
There was a thread some time ago that if you have made some little changes in a scene,that you can use the ploprender tool to rendern only that special part of the scene and add to the rest. How does that work,and im using b4
Aldaron posted Sun, 23 June 2002 at 10:04 AM
Once your changes are made then bring up the picture again, click-drag around the area you wish to re-render. A box should appear with 2 buttons and a triangle next to it, click the small button (not the ones way to the left of the screen or you'll re-render the whole picture) and just what is in the box will re-render. Once it's done select the small triangle and collapse selection then save image as you usually do.
thgeisel posted Sun, 23 June 2002 at 12:09 PM
Thanks alot!! Got it !!!!
