Subject: My Camera and Lihjting controlls have disapear-Please Help
notime6 opened this issue on Jun 23, 2002 ยท 5 posts
notime6 posted Sun, 23 June 2002 at 10:17 AM
The window where my figure is and the camera controls and the light controls....I restarted the computer and then the program and got the figure window back but not the controls. I changed the resolution on the computers windows display and the controlls came back but the resolution makes the printing too small to work with comfortably.. I changed the res back to 800x600 and the controls disapear again.....Does anyone know any way to fix this with out reloading entire program? Thank you all for all the wonderful advise you post
Dagon posted Sun, 23 June 2002 at 10:34 AM
Go into Edit/General Preferences set document and interface to factory state. Restart Poser and it should be fixed
darkphoenix posted Sun, 23 June 2002 at 12:32 PM
change the resolution to the higher one, click on the name of the controls and then drag the control back to where you would normally be able to see it at 800x600, then change your resolution back again.
notime6 posted Sun, 23 June 2002 at 1:22 PM
Thanks for your help That worked
ronknights posted Sun, 23 June 2002 at 3:44 PM
I'm not at my computer right now. But I believe there is a Window or Library drop down menu. From there you select the tools you want to see on your workspace. Sometimes things get unchecked, and you recheck them.
