fuchsia16 opened this issue on Jun 24, 2002 ยท 5 posts
fuchsia16 posted Mon, 24 June 2002 at 7:16 AM
retrocity posted Tue, 25 June 2002 at 12:30 AM
have you tried the "texturizer" filter (Filter --> Texture --> Texturizer) and select the Sandstone preset?? If this does not give you the graininess you want, try adding "noise" to a gray layer and select Gaussian and check the Monochromatic checkbox. Adjust the amount (%) of noise in the slider before applying the filter... just an idea, :) retrocity
fuchsia16 posted Tue, 25 June 2002 at 10:13 AM
thanx retrosity. i will try it.
Hoofdcommissaris posted Tue, 25 June 2002 at 10:20 AM
Lighting Effects might have been used with an alpha channel filled with noise and some bevelling as well. You can get very nice results with that. If someone wants some information on that, just shout.
retrocity posted Tue, 25 June 2002 at 10:57 AM
Good idea Hoof, maybe run the "clouds" filter on another layer and lower the opacity to give it a "mottled" look...
