TheEdgeFilms opened this issue on Jun 25, 2002 ยท 3 posts
TheEdgeFilms posted Tue, 25 June 2002 at 10:23 AM
Hey how can i get a hole or a dent in the head of a poser 4 man character im trying to make it look like imhotep from the mummy and i want the hole in the head and i want holes in the body.
darkphoenix posted Tue, 25 June 2002 at 11:10 AM
try using morphs and transparency map settings on the skin. Your transparency map should be a texture map similar to your color map but in black and white, with pure white in the places you want the skin to appear and pure black in the places you want nothing. You have to play with the transparency fall off effects to get a good result. Also, you will need several skin textures, and render your image with each one and composite them in layers in photoshop. it will take a lot of playing around and messing with the settings. For your bimp maps, use a regualr bump map, but increase the brightness a good deal and then paint pure black on the areas where the holes will be to give it that deep look.
TheEdgeFilms posted Tue, 25 June 2002 at 1:48 PM
how would i be able to make a movie in the same way? Because thats what im trying to do a mix between live actions and the 3d creature. But thanks for the transperancy and bump information it really helped. -Peter
