TheWanderer opened this issue on Jun 26, 2002 ยท 9 posts
TheWanderer posted Wed, 26 June 2002 at 4:37 PM
Hi just found some excellent plant models to use... but.. when I import them into poser and export them as obj files when I render them they develop a diamond dimples effect like the geodesic sphere at epcot. anyone have any ideas? thanks Dave
psychofish posted Wed, 26 June 2002 at 5:13 PM
im not sure i know what i'm talking about, but try going to the render materials window and taking off any highlights...
whattawa posted Wed, 26 June 2002 at 5:58 PM
Is there is a possibility that they aren't welded? If Poser doesn't smooth them, it's because they need to be welded.
TheWanderer posted Wed, 26 June 2002 at 7:00 PM
Kalypso posted Wed, 26 June 2002 at 8:29 PM Site Admin
Attached Link: http://www.toucan.co.jp/product/3ds/garden/modelsE.html
Did you by any chance get these from Toucan's? Because if so, he has modified all his meshes and they now render beautifully. Just a couple of days ago I imported them all (in 3ds format) and resaved them all as props. Since they come with maps that means they've already been uvmapped hence no need to turn them into .obj's, only makes the mesh bigger. In case you didn't get them from Toucan's do so right now! :) And if you're interested check out the fish as well, also very great models http://www.toucan.co.jp/product/3ds/3dsFrameSetE.htmlronstuff posted Wed, 26 June 2002 at 9:25 PM
HI - I've had this happen with plants too. It seems to be a combination of reversed normals, and sometimes welding also. But try reversing the normals, using the grouping tool before you weld. Welding sometimes make things rounded that are supposed to have sharp edges, so do that after at least trying the normals.
EricofSD posted Thu, 27 June 2002 at 1:23 AM
Attached Link: http://www.kurtz-fernhout.com/PlantStudio/help/index.htm
Kalypso, those meshes are delightful and they remind me of Plant Studio meshes that were altered. Maybe going back to Kurtz is a good idea.Kalypso posted Thu, 27 June 2002 at 4:04 PM Site Admin
EricofSD, I didn't know Plant Studio has become GPL free software! I'm downloading my copy right now :) As for Toucan's site, I don't think they've been ripped off as he's selling the higher res models with hi-res maps on TurboSquid. ronstuff - when I first downloaded them I tried everything you mentioned but no dice. I remember running into a similar problem with meshes made in Imagine, .iob files. Even after making them obj's and trying everything they would still render like this. At some point I went back to Toucan's and he said he had been informed of the problems Poser users were having and was modifying them. After redownloading them I found they worked perfectly. I wish I knew what he had done and if anything can be done to all these .iob files I have.
ronstuff posted Thu, 27 June 2002 at 7:16 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=760796
If it isn't normals or welding, then the only other thing that it is likely to be is triangulatioin. Follow this link for an example. Sounds like this is what you are seeing. Poser is very sensitive to vertex rotation order (the sequence in which the vertices are enumerated in the file) By changing the sequence of 4 points (which describe two adjacent triangles) you can alter the location of the one common side, then the renderer does not get confused on the shading.
