Forum: Animation
Subject: What to use?
andtfoot opened this issue on Jun 27, 2002 ยท 5 posts
andtfoot posted Thu, 27 June 2002 at 2:48 AM
Ah well... I'm planning to make a menu system revolving around a picture I have rendered. I should then be able to click on one of the things, say the dvd case as an example. After that, I should be able click on the result to open up a seperate program.(see next message) What should I use to make this effect?
andtfoot posted Thu, 27 June 2002 at 2:53 AM
Here is the result I want from clicking on the object...
digitek posted Sun, 30 June 2002 at 12:50 PM
I dont understand what effect you are trying to make, could you explain a little more in detail and maybe I can help
andtfoot posted Mon, 01 July 2002 at 1:29 AM
Basically, I want to click on the dvd, an animation will happen, bringing the dvd up the front, and then me being able to click on the result of this to open up a program. Hope that helps.
saxon posted Tue, 02 July 2002 at 8:36 AM
Flash if it's for the web, Director if it's not....
