Subject: Duplicate folders
RawArt opened this issue on Jun 28, 2002 ยท 5 posts
RawArt posted Fri, 28 June 2002 at 6:05 PM
Hello again I put up a post earlier about re-organizing my files in the poser directory...but now that I am home and can look at them, I found that I have 2 "runtime" folders..they each have some of the same stuff, and some different stuff....so I dont know if this is normal, or which one I should be editing out. Any clues? or should I just re-install and start with a clean slate Rawn
Thornod posted Fri, 28 June 2002 at 6:48 PM
Poser will only look at the Runtime directly below it. It will ignore your deeper folder. I would copy the second Runtime into your Poser root. You will recieve errors about directories already exists: click yes or yes to all. IF you have different items in the second Runtime they will be added to your working folders. Then you can delete the second Runtime folder.
MAKE A BACKUP OF THE POSER DIRECTORY BEFORE YOU DO THIS!
I've done the many times myself. Usually its my fault because I've chosen one level down too many on a prop or figure install.
Good luck.
Thorn
RawArt posted Fri, 28 June 2002 at 8:21 PM
Thanx That cleared up the double folders...and everything still seems to work.....now I just gotta organize the files :) Rawn
ronknights posted Fri, 28 June 2002 at 9:50 PM
Do NOT copy the second runtime folder itself into the correct one. Copy the contents. You might want to look things over to be sure what you're really doing.
Jazzmin posted Sat, 29 June 2002 at 1:50 AM
This could have happened when you installed from the .zip directly to your copy of Poser.
Some .zip/.exe are set up to install one of two ways:
Metacreations/Poser/Runtime... etc etc etc
or
Curious Labs/Poser/Runtime... etc etc etc
If you have the Curious Labs version and install the .zip with the Metacreations file name then Poser will create a duplicate Runtime folder... hence the duplicate runtime folders you had.
To avoid this problem, I make a temporary folder and install the .zip to that folder and then cut and paste the folders within the geometries folder to my version of Poser gemoetries, then characters/props/poses, etc... Problem solved, no duplicate Runtime folder issues to deal with. Then delete the temp folder.
Jazz
Vive Bene.  Spesso L'Amore.  Di Risata Molto.
Live Well.  Love Often.  Laugh Much.
