DocMatter opened this issue on Jun 30, 2002 ยท 11 posts
DocMatter posted Sun, 30 June 2002 at 10:13 PM
jerr3d posted Sun, 30 June 2002 at 10:18 PM
try going under Window/Document window size and changing the size either bigger or smaller and see if you can move the window then. On the same subject, what bugs me is how the names of the dials are half hidden under the numbers. hope poser 5 fixes this!
Little_Dragon posted Sun, 30 June 2002 at 10:20 PM
Yes, there's an easier fix. After you get everything straightened out again (the hard way), use the UI dots to memorize your workspace configuration. The next time it gets screwed up, you can use the dots to restore, and you won't have to restart Poser to do it.
DocMatter posted Sun, 30 June 2002 at 10:22 PM
Jerr-- I've tried your method and it doesn't help. It just gets bigger but stays in the corner. LD--I'll try your idea. I never use the UI dots, so I forgot about them! I'll let you know. Thanks to you both.
ronmolina posted Sun, 30 June 2002 at 10:27 PM
Make sure you have the latest patch. I use to have this problem too. Ron
bwldrd posted Mon, 01 July 2002 at 12:47 AM
Make a backup of you preffered state pz3 in the Runtime:prefs directory. Then just restore it when this happens. Have to close and re-open poser though.
Consider me insane if you wish, but is your reality any better?
PhilC posted Mon, 01 July 2002 at 2:50 AM
Yes the UI dots is the best way but once I had this happen to me before I'd set that up. What I did was type "po2" (no quotes), which brings up the Poser 2 interface, followed by "po3" which returned me to a correct Poser 3 setting.
ronknights posted Mon, 01 July 2002 at 5:42 AM
DocMatter posted Mon, 01 July 2002 at 8:19 AM
RonM--I have the latest patches and ProPack, so I don't think that's the problem, but thanks anyway! RonK-- I use your method to set my preferred state to what I want. The problem is that every once in a while, Poser decides to change it by moving the picture up to the corner where I can't drag it back to where its suppossed to be. But I think using the UI dots will help keep it in line. Thanks for your help, though!
TMGraphics posted Mon, 01 July 2002 at 12:40 PM
Note - easiest and best way is defined by personal preference.
ronknights posted Mon, 01 July 2002 at 10:07 PM
I'm just glad when someone licks that pesky problem!
