aeryk71 opened this issue on Feb 24, 2000 ยท 12 posts
aeryk71 posted Thu, 24 February 2000 at 10:10 AM
ClintH posted Thu, 24 February 2000 at 10:12 AM
Really shows of the texturing abilities of Carrara. Cool image. Cool work. Hey Aerky, What do you do for a living? If you dont mind me asking.. ;) Clint
Clint Hawkins
All my life I've been over the top ... I don't know what I'm doing
... All I know is I don't wana stop!
(Zakk Wylde (2007))
aeryk71 posted Thu, 24 February 2000 at 10:42 AM
Clint, I sent you a message via the forum message sender thingy (I know, very technical. :) Did you get it? Aeryk71
Tuck3D posted Sun, 27 February 2000 at 1:10 AM
Aeryk71 I wish you would post the recipe for that shader in this picture. ( The one in the bottm left) I would really appreciate it. Tuck
ClintH posted Sun, 27 February 2000 at 6:52 AM
Tuck - Thats a standard one with Carrara. Do you have Carrara? Clint
Clint Hawkins
(Zakk Wylde (2007))
aeryk71 posted Sun, 27 February 2000 at 10:17 AM
That is the Lava Flow (Hot) shader in Carrara. Aeryk71
Tuck3D posted Sun, 27 February 2000 at 9:20 PM
I have Carrara And don't seem to have that shader listed. What catagory is it under or supposed to be under. Thanks for your help. Tuck
ClintH posted Mon, 28 February 2000 at 1:56 PM
Tuck - It should be in the Shader Browser folder called Nature - (Begley) Its called Lava Flow(Hot) Clint
Clint Hawkins
(Zakk Wylde (2007))
Tuck3D posted Mon, 28 February 2000 at 10:35 PM
OK this is so weird!!! I donthave a shader folder called Nature. Clint......Help. I did a full install when I installed it. Tuck
ClintH posted Tue, 29 February 2000 at 9:42 AM
Tuck! No, Thats a drag Ok - Did you do a "Custom install" when you installed? I cant remember if the extra shaders where part of the "Custom Install" or not. The path to the shaders that shipped with carrara is this. (directory where you installed Carrara)/More Preset/Shaders/ This is the Folder (Directory) where you will find all the "Begley" Shaders. There are 6 folders for these shaders. Animal (Begley), Interior (Begley), Metal (Begley), Misc (Begley), Nature (Begley) and Planet (Begley). Now the default shaders are stored in: (Carrara Folder)/Presets/Shaders/ There are 6 folders here also. Basic Metals, Basic Procedurals, Basic Refraction, Basic Shaders, Basic Transparancy and Complex Procedurals. The above "Basic" and "Begley" are all the shaders that were loaded when I loaded Carrara. I always to the "Custom Installations" for all software. So Im pretty sure I did it when I installed Carrara. Maybe there is a check box in there somewhere about loaded extra shaders.?? Not sure. Also - Yank out the Carrara CD's (2 of them) and look around for the folders. If you find them Just move them from the CD to your Hard disk. Then go into the Carrara Shader Browser and Add the new folders that you just copied to your HDD. I hope this helps.... If not you knwo where to get me.. ;) If it doesnt help let me know. We can get ya fixed! ;) Good luck and best regards, Clint
Clint Hawkins
(Zakk Wylde (2007))
Tuck3D posted Wed, 01 March 2000 at 11:54 PM
Clint You were correct again!!! It was the install and just for your info and now mine. On standard install you do not get Extra Presets, Tutorials, or Icon Manager. Now we all now. Thanks for your help. Tuck
ClintH posted Thu, 02 March 2000 at 8:28 AM
Tuck - Its always a pleasure. Have fun with Carrara. If you have anymore problems/questions or issues, as always, post away. Regards, Clint
Clint Hawkins
(Zakk Wylde (2007))
