Niles opened this issue on Jul 06, 2002 ยท 3 posts
Niles posted Sat, 06 July 2002 at 8:45 PM
I need some help with this, I have only used a few DFX models and I have not had any problems with them ... till now. I downloaded several last night and am trying them now, with not much success. When I import them I get this and other messages. "3D facet data was found in BLOCKs. Object instancing is not supported, so olny one copy of each object will be created." Also I get message "This DXF file does not contain any 3D facet entity data and hence no model was imported." Any ideas guys and gals "hence" I have no clue. (had to use that word hince) :) Thanks Niles
nerd posted Sat, 06 July 2002 at 9:42 PM Forum Moderator
Hate to say sorr, but sorry. You are going to need to run these models through a 3D modeling prog that speaks DFX. Posers DFX import is pretty limited and the model you are importing is too much for it.
Grey_cat posted Sat, 06 July 2002 at 11:38 PM
DXF stands for Drawing eXchange Format. It's a file format intended to be used to transfer drawing files between drafting packages. It is not a 3d file format, though it can have 3d information in it. You really need to know what the file was intended to be used for.
