Darth Opus opened this issue on Feb 26, 2000 ยท 7 posts
Darth Opus posted Sat, 26 February 2000 at 4:13 PM
PhilC posted Sat, 26 February 2000 at 4:23 PM
Yep I'd say that is a good likeness Now how about "THAT" dress? :)))))))
picnic posted Sat, 26 February 2000 at 5:33 PM
Darth--very good. I'd shorten the space just a tad between her nose and lips-maybe broaden the nostril area just a tad too. Its SOOOOOOOOOo close. Diane B
picnic posted Sat, 26 February 2000 at 5:34 PM
What I mean is the lower nose--it seems just a bit thin through the middle whereas Jennifer's is a bit broader--if you get what I mean--the 'broadness' that you have used starts up just a bit higher--don't know if that's possible though. Diane B
duesentrieb posted Sat, 26 February 2000 at 6:05 PM
Still some way to go... The nose should be wider, her mouth too, eyebrows should bend and the chin looks too bold. I'm curious what you make of it!
Eric Walters posted Sat, 26 February 2000 at 6:23 PM
Fine work so far-a little more and you will have it. I worked on creating a character of my good friend Kathy after Jeff posted a character for Azymuth that resembled my friend enough to inspire me. He kindly sent his Sarah character to me and away I went-added some 15 morphs to an already heavily MT'd character and created a texture map from a picture of her face. I am much closer=but not there yet. I created morph targets in RDS in the past but I am going to try in Amorphium and in P4 using the fine tutorials on Morphworld2.0! Have you made a texture map based on her face?? IF not try it-it can help-provided you get the texture correct! Eric Walters
Art posted Sat, 26 February 2000 at 9:12 PM
Looking good. Lower the chin a bit more and raise the eyebrows some. Flatten the nose a little more. If worse come to worse regarding the hair, simply do a cut and paste of the original and see what it looks like. Half Joey - You seem to be half-way out of luck making such a request here! I doubt you will get any key from the folks on this forum! I think Metacreations will probably be able to supply you with one. www.metacreations.com
