Moonstone opened this issue on Jul 10, 2002 ยท 5 posts
Moonstone posted Wed, 10 July 2002 at 9:16 AM
Aldaron posted Wed, 10 July 2002 at 9:38 AM
To turn off the sun got to the skylab (accessable by clicking sky&fog then clicking the little cloud/rainbow) at the bttom right is a little button "disable sun". As for the windows, make the wall positive by going into attributes then make the cubes that will cut out the windows negative and group the wall and cubes...instant windows. Then you can add frames and glass, etc.
EricofSD posted Thu, 11 July 2002 at 12:30 AM
Or if that doesn't work, go to the lab, turn ambiance, sky dome and sunlight to black. If that does't work for you, put a large box object around your work area and move the camera inside, then use lighting objects to simulate indoor lights.
Spit posted Thu, 11 July 2002 at 3:53 AM
The easiest way to turn off all the sun and sky stuff is to choose 'simple black background' from the sky presets AND disable sunlight in the skylab.
Moonstone posted Thu, 11 July 2002 at 8:42 AM
Thanks everyone, I am gonna try what you just suggested about turning off hte sunlight. I am gonna try it and then if it turned out great and I will post the image again to see if it looks better or not.
