Subject: Boot trouble with Poser 4, 117 patch
arcady opened this issue on Feb 28, 2000 ยท 4 posts
arcady posted Mon, 28 February 2000 at 1:57 AM
Anyone know what's causing this and how I can fix it? This figure was fine last time I opened the file, near the end of january. I've since installed the 117 patch. When I open the file this is what I see. You're basically looking at the poser 4 nude woman using the 'Matsumi' character found in characters-female; the leotard, some shuriken from the dark props set, the boots that come with poser 4, and the cylinder object. Finished off with a custom texture. When I take the matsumi character straight out of characters menu and put boots on her though they load up fine. But on this old save if I delete those two boots and apply new ones they still end up wrong.
Truth has no value without backing by unfounded belief.
Renderosity Gallery
MDibble posted Mon, 28 February 2000 at 8:02 AM
Try turning off the IK for the boots and re-conforming them. Mike
arcady posted Mon, 28 February 2000 at 10:47 AM
Should I then turn it back on after I conform and save? I'll give it a test run tonight. I just went to test this on the Mac and when I opened the file there she came up fine. My Mac copy is on the same patch version. So as a test on the Mac I turned off the IK for each boot and they went haywire. Poping up and behind her. Then I re conformed them and they fit fine. Of course on the Mac they also fit fine before I turned off the I.K. When I flip I.K. back on after the reconform they still look ok. So as an additional experiement I turned off I.K. again and they got wierd. Then I turned it back on and rather than go back in place they got wierder (moving to the side of her and bunching up). Strange indeed. I'll know what I get on the PC tonight.
Renderosity Gallery
CEBrown posted Mon, 28 February 2000 at 1:19 PM
I've had strange results like this with Posing the PROP instead of the character... That could be it. I also had my P4 Nude Woman become corrupted; it was IMPOSSIBLE to pose her; looked like moving spaghetti around. Bizarre. Upgrading fixed this, fortunately!
